Diagnostics
Reactions
Tewkesbury
Non-US
United Kingdom
2014 XC60 Lux 4WD
My XC60 (2014) is showing numerous status errors namely: CEM; ECM; ABS/BCM/; DIM;PBM; DEM; DDM;DDM, PDM, PSM; PSCM;CVM. These have been cleared but shortly afterwards, once again the ABS light illuminates and the car enters "limp mode".
I and my garage are mystified, I would appreciate any ideas on where to start to sort this out. There was an engine change last year following a belt failure at 40,000 miles.
A starting point may be the turbo boost sensor and intake air temperature sensor. Also suspect a wheel speed sensor. Am I on the right track?
